Hey @Gene! Can you please add me: https://www.wunderground.com/dashboard/pws/KTXKATY120?
@davispeden done (link), cheers
Gene
Any chance you can add - https://www.wunderground.com/dashboard/pws/KMOVALLE7
Thanks
Hello. Can I get
https://www.wunderground.com/dashboard/pws/INANAIMO50
Added.
Thank you
@Ryan1 done (link), sorry for the delay. Lack of state information within your WU profile caused a bit of issue with pwsweather. Had to add an alternative lookup so this does not happen in the future.
Thank you. Much appreciated
Greetings,
Any chance my station could be added:
https://www.wunderground.com/dashboard/pws/IBAIED2
Many thanks
@Bonsch Done (link), be on the lookout for PWS_Wx70354
My Weather Underground used to push data to the PWS Weather site but it no longer works. Can you please assist Gene? Thank you!
WU: www.wunderground.com/dashboard/pws/KAZSCOTT328
PWS: www.pwsweather.com/stations/profile/AZSCOTT328
@aekemmerer Done (link), be on the lookout for PWS_AZSCOTT328
@Gene Could you please add my pws thanks for your continued support.
@Shadow Done (link), be on the lookout for PWS_Wx22210,.
Keep in mind, since this is an AcuRite station, you may have better long term support by using data from myacurite.com instead of weather underground. If you ever need to switch, simply message me (link) you acurite hubâs ID (mac address) and I can switch you over.
Cheers,
Gene
Ok thanks. Will look into that. As i am using the built in wifi acurite vs the separate hub you would need the mac of the display correct?
No, the mac address (or ID as acurite calls it) of your access hub. This is the same number youâve used to register with myacurite.com and it is listed under Device ID here: https://www.myacurite.com/#/devices
P.S. I stand corrected, didnât really fully realize what you have been talking about in your message as I didnât know that AcuRite has made a version (link) with a display that has WiFi connection. Alas it seems that the only way to support this model is via weather underground (as we have it setup now), since it does not send data to myacurite.com.
@Gene Could you please add my pws? Thanks in advance.
@cordump2001 Done (link), be on the lookout for PWS_Wx56852
If we ever run into issues with WU support, keep in mind that Ambient Weather supports pwsweather directly, more on this here (link), and/or you can create and send me an API key here (link) and my code can acquire data directly from their servers, instead of WU.
Yeah looked into this and tried but doesnât connect to the acurite site. Looks as though it only uses the darksky and sends data to underground.
https://www.acurite.com/hd-wi-fi-display-for-5-in-1-weather-station-with-future-forecast-powered-by-dark-sky-and-weather-underground-streaming-display-only.html
