Watering time in seconds
Hello, I purchased the Rachio 2 controller for my orchid greenhouse to control my misting/watering and fogging systems. After doing the install, I noticed I do not have any options to setup watering in seconds? Even through IFTTT.
Did I miss something? How hard can it be to include a seconds options? This is a must have feature, 1 minute is far too long of a watering time for many applications! Can someone help me accomplish that? If not, I’m afraid this controller is useless for my needs.
This thread has a script to run a zone for a specified number of seconds. Modify it to run multiple zones, or otherwise as needed for your application:
Hear, hear! IMHO, Rachio has a ‘style trumps substance’ culture and did extra work to remove the seconds option. If the duration fields for a schedule were simple text boxes where you type in the number of minutes, you could enter e.g. 0.2 to get a 12 second run. But they thought it was cute to have + and - buttons, which add or subtract a minute with each tap. Fine, but how about you also allow tapping on the number, where you could then type something in, including a decimal point if needed.
Thanks Stewart. How would I go about configuring this from an Android device? I only use a computer (Windows) at work… And don’t know anything about that Perl thing.
I still cannot believe they have no option within the app for this. Why don’t they have an option in settings you can enable to allow manual time input instead of this stupid ± scrolling option? Or why don’t they just have an hour, minutes, and seconds options in the ± time setting option? I cannot be the only one with this need. All the watering controllers I’ve seen offer a seconds options, this is pretty common and should be a standard feature.
Any idea if this was ever implemented? I have one zone in one schedule that has a runtime in seconds but can’t find a way to repeat this for the life of me. If I can’t move runtime to seconds I think I’ll just install a Wyze unit as 1 minute is just way too long for watering my container garden - and reducing the flow rate on the zones kills the functionality of the spray heads. Anyone have an idea if this zone is just a fluke - or maybe functionality that was introduced but has since been removed - or if there’s a way to replicate this sub-minute watering? Thanks!
Hi @Grumblepunch,
Thank you for flagging this. Our software does not have the ability to edit zone run times in seconds. I am not certain why your watering duration shows in seconds, but I have raised the issue with our Engineering Team to investigate as I am unable to replicate this on my Android and iOS devices.
I’ll keep you posted.
A simple solution may be to use SmartThings - you rather lose the point of a smart controller (staggering zones, weather intelligence, etc.) but at least this would enable you to have run times in seconds without needing to write code. Thought this might help someone.
