Hello, I posted a similar question and was referred to this thread ( Watering time in seconds ) for the strawberry Perl solution.
I really need to be able to set watering times to less then 1 minute. Reading this thread is making me seriously regret this purchase…
The low tech solution is to enable the user to simply set the watering time to what they need. Who decided that watering should never be less then 1 minute? Is this controller meant to only water grass and nothing else? I understand for most watering needs, 1+ minute is fine, but some applications require a few seconds only.
Reading that it’s not even on the road map sounds crazy!? This should be a really simple fix to make your users happy. If you do not want it in the app for everyone, then couldn’t you allow us to enable an option in the settings to show the seconds ± time set option? Or allow users to manually input the time for use with decimals?
Please help!! Or I need to reconsider this controller.
