Water adjustment
@twin1, I do not know the answer to the new water adjustment feature. I presume you are referring to the “Enhanced Watering” that @dane mentioned. Are you a Thrive subscriber or did sign up to help? I just sent my request to help with this new feature and understand it more.
I have not seen much about “Lawn Champion” and “Weed Watcher” that @dane also mentioned, so do not really know what those are. However, I did notice “Thrive” kind of being up front seems to be gone. I did find under “Yard” a “Cultivate” and “Journal”. I have not figured out what those are either, but have not spent much time looking. Under “Cultivate”, it indicates “Vigor 80%”, “Lawn Champion level” nutrient level is low (I do give it nutrients), suggest mowing at 4" (which I do), and watering kind kind of a lot (but that is what flex daily is doing probably because of the high sand content and heat).
