@Gene Thanks for doing this. Whenever you get a chance could you add mine to PWSweather?
@Gene Thank you for your help in advance. Could you please add the following station too?
https://tempestwx.com/station/19914/
https://www.wunderground.com/dashboard/pws/KFLDAYTO103
Is @Gene still around doing this? I receive my Tempest in 2 weeks. If he isn’t actively adding anymore is there an easy way for us users to do it ?
I’m still here, I just started replying to people requesting stations via a PM, if you see me liking a post, it means that the station was added.
Great! Thanks for the update and continuing to help out users!
Gene, can you add my weather system to your list as well?
@Gene I was hoping that I could get my weather station added. It shows up on the map as a PWS but I cannot select it for my Rachio. It is a Weatherflow Tempest.
https://www.wunderground.com/dashboard/pws/KMIADATO19
or
https://tempestwx.com/station/22280/
Thanks,
Chris
Are you using a Gen 3 controller? Your weather underground station is still new, it will take up to two weeks for it to pass the QC process and show up as a choice to Rachio with WI+ support. I usually help people add their data to pwsweather, in order to use it with older Gen 1 and 2 controllers (among other things).
Hi Gene,
Yes, it is brand new and installed last week. That is fine if it will take a bit to show up.
I actually do have a Gen 2 16x zone controller (for some reason I thought I was Gen 3… sorry).
Chris
Hi Gene-
I’d love it if you could add my station to PWS
https://www.wunderground.com/dashboard/pws/KMNLAKEV113
https://tempestwx.com/station/21542
Chris
Can you add my Tempest so I can access it via Rachio: https://tempestwx.com/station/23906/
@Gene Greetings,
May I jump on this train, please. Rachio Gen 2 and want to get my Tempest linked to PWS
https://tempestwx.com/station/21595
https://www.wunderground.com/dashboard/pws/KPAWATER23
Thanks, Dave
@Gene can you please add my tempest so I can access via Rachio?
https://tempestwx.com/station/23376
https://www.wunderground.com/dashboard/pws/KNEOMAHA657
@Gene Can you please add to my Tempest so I can use with Rachio?
https://tempestwx.com/station/24322/
https://www.wunderground.com/dashboard/pws/KILNAPER115
Thank You!
@Gene Can you please add my Tempest so I can use with Rachio?
https://tempestwx.com/station/24426/
https://www.wunderground.com/dashboard/pws/KMNPRIOR68
@Gene Can you add mine also I have Rachio Gen 2 and want to get my Tempest linked to PWS
https://tempestwx.com/station/18705
https://www.wunderground.com/dashboard/pws/KILLOMBA40
https://tempestwx.com/station/25272/
or
https://www.wunderground.com/dashboard/pws/IGATIN25
Thanks
@Gene As with everyone else, can you please add my weather station to whatever secret list gets the data to a Rachio V2 controller:
https://tempestwx.com/station/26503/
https://www.wunderground.com/dashboard/pws/KCAENCIN729
Thanks in advance!
Hi Gene. After 2 full days of banging my head against the wall I found this and you! Would you please add me as well? Thank you.
@Gene
Could you please add mine too !
