Thanks for the update.
Contemplating on purchasing (debating between Netatmo and Tempest). Will be my first PWS. How do you have your Tempest mounted if I may ask?
It’s sitting atop a 10 foot long, one inch diameter galvanized pipe. I have it mounted with two brackets onto a concrete column on the second floor of our terrace. The Tempest unit sits 22 feet above ground level and is extremely sturdy. The installation is a bit overkill, but I wanted to mitigate any chance for vibrations. We also get a lot of thunderstorms and hurricanes here in South Florida, so I wanted to make sure we were prepared for whatever comes our way.
Thanks. Would love to see a pic.
Could you please add mine as well?
https://www.wunderground.com/dashboard/pws/KMNOTSEG37
I’ve messaged you for more info
Hi @Gene
May I request https://www.wunderground.com/dashboard/pws/IKUMEU11 for my weatherflow station to be used for my Rachio please. https://smartweather.weatherflow.com/station/7049
Thank you.
Gene
Could you please send my station information to pwsweather too?
Thanks,
Eric
@Gene so sorry to be a pest, but if you can, would you please add my station information as well?
Still have a Gen2 rachio, so can’t use WU PWSs directly.
WU: https://www.wunderground.com/dashboard/pws/KNJMULLI14
WF: https://smartweather.weatherflow.com/station/18959/grid
Thanks in advance!
@jrapoport Just a heads-up that with your Tempest, you can use the shorter URL:
https://tempestwx.com/station/18959
…or…
@ZoneOne seems the links are not limited to Tempest, older Air & Sky stations are showing up as well.
Thanks! Just got my tempest so still figuring it all out. I guess it’s just a shorter url for the same data, not sure why the double sites on their side tho.
Gene,
Could you please add my station information:
https://tempestwx.com/station/19490
https://tempestwx.com/station/19490/grid
Thank you!
Hi Gene! Thank you for your help in this community!
Could you please add my station?
https://www.wunderground.com/dashboard/pws/KMANATIC49
https://tempestwx.com/station/19128/
@Gene could you please add my Tempest?
https://tempestwx.com/station/20532/
https://www.wunderground.com/dashboard/pws/KNELINCO357
@gene I know you’ve been bombarded by a lot of requests. I’d like my Tempest added to PWS to
https://tempestwx.com/station/20679/grid
https://www.wunderground.com/dashboard/pws/KNCSUMME47
Thanks a ton!
Cary
@Gene Hi Gene, thank you for all that you do! Whenever you get a chance would you mind adding my station to PWSweather? Thank you!
https://www.wunderground.com/dashboard/pws/KNCWAXHA116
How do I get Rachio to see my weather flow SKY station?
https://www.wunderground.com/dashboard/pws/KCASANJO1185
Thanks,
Eric
@Gene , how in the world are you getting our stations added to the PWS list? Would love to know. I need to add three of them, the first one is below.
