Hello, has anyone here successfully used a Toro TFS-075 wired flow meter? I recently installed one, brand new. When I compare the water usage reported by my Rachio Gen 2 to my city meter, the Rachio reported usage is consistently about 5X too high. I would set the K-factor (0.15630) and offset (0.9) myself, but I do not see an obvious way to do that.
I opened a ticket with Rachio support over a week ago, and I have not yet received any response.
Ah, sorry. To be clear, it would be helpful to be able to enter the K and Offset, but it appears that Rachio has that locked down. Iām guessing that Rachio needs to vet each make/model of flow meter so that they can support it. Newbie question: does anyone from Rachio post in these forums?
First, make sure you are connected to āSensor Commonā and S1 on GEN2.
It is important to note that all that happens when you choose your meter from the list is that the K and Offset are supposed to be chosen to match that meter. So, if you picked it from the list, it should have already populated those values you mention.
If all that is good, since you are over counting by that much, it mostly leaves either an interference problem, a strangely defective meter (that would be a odd failure mode), or the correct K and offset were not populated and there is a bug.
One possible way to check for interference (though far from perfect) would be to remove the common from the controller (but not S1) and you should record 0 gpm. If not, that could be the issue.
S1 - check. Removed the lead to SC, ran a zone for a few minutes - 0 litres consumed, and I got a low flow warning for that zone (which of course would be expected). Unless the flow meter is defective, Iām wondering if itās software.
Iāll try changing the units back to imperial (currently metric ⦠Canada here, eh).
Iāll also try setting the flow meter to a different one in the software ⦠maybe I can approximate the ātrueā flow by choosing the āwrongā flow meter.
The unit I have (not in use) which at one time was functioning with a CST meter attached is definitely not a short between S1 and SC (or S2 and SC). That sounds defective if true. (I am assuming this is with meter disconnected.
@franz or @laura.bauman, do you have anyone in tech support who can help me out here. And please do not ask them to send me the FAQ, I read it before posting here, and before opening a ticket through the Rachio app. It would be helpful to confirm whether your software is using the correct K and Offset for the Toro TFS-075, which I have specified earlier in this thread. Thanks
Hi @franz, my irrigation ran this morning with all 8 zones reporting flow from one-third to one-quarter of the previously calibrated values. In other words, the latest usage reported by Rachio appears to be consistent with the city water meterās. Thanks for following up on this.
I think this change affected me in the opposite direction. All my zones started reporting 2.5x higher starting about 4 days ago. For example, my previously 9.5 zone is now reporting 25. If that were true, the heads wouldnāt even come up. Iām using Toro tfs100 in settings.
@edbdfish it is possible that some of the K-factor / offset pair were correct to begin with ⦠@MeterManSays might want to weigh in on that. In the meantime, if you havenāt already done so, open a help ticket in the Rachio app. Please let us know how it goes.
