I had bought a rachio 2 a long time ago and never got around to installing it. I now want to install it but having trouble figuring out what to connect where.
I have rain sensor but it seems like the old controller didn’t have a sensor port and seems to be “inline” with the common wire. I have two cables that come in from the outside, I believe one is for the “master pump”, and then another for the different zones.
In the first picture below you can see the white wire entering. That is from the rain rensor. The brown wire from that goes to the COM port on the controller. Red wires from that goes to the 24Vac ports on the left. The white wire from that goes to a wire nut, which is connected to two other white wires from wires that com from the outside. There is also black wire that goes to the Master port from a cable coming from outside. There are also the different color cables that go to the zone #'d ports.
I do’nt really care about having the rain sensor so how should I wire it up.
My initial hunch is that I have to undo the cables from the wire nut and the white wires that were going into that that came from the two cables leading into the box go to C ports on the rachio instead of the existing brown wire that went to the COM port. The brown wire that was coming from the rain sensor is not needed anymore and thus is removed. (This went to the COM port initially). All the wires from the 24VAC port are not needed, two were going to rain sensor and two were powering the initial controller.
The zone 1-5 wires go to the respective 1-5 ports. The black wire going to M goes to M on the rachio.
Does this seem correct? I think the thing that trips me up is that it seems like the rain sensor didn’t have its own port and so was connected to the 24V ac and the common, and the common wires of the zones and the master pump were connected through the rain sensor.
I’m guessing the ports are the same as labeled in this picture since they don’t seem to be labeled on the box. The picture is from another post for a 476pri controller.
