I purchased the Rachio 3 and trying to find a good image of the wiring from the ESP-8si to Rachio 3? Thanks.
A picture of what you have is helpful. Here is a manual for that model: Rain Bird ESP-Si User Manual
However, I do not see the exact layout of wires for that model, a 6 instead of an 8 is on page 12. I would guess an 8 might be as follows, left to right, and how they connect to the Rachio.
- 24VAC β do not connect to Rachio, use Rachio supplied power adapter
- 24VAC β see 1
- COM β Rachio has more than 1 βCβ connector. If you have more than one wire, it does not matter if they are connected together or all separated (although, I personally would connect separately)
- MV β Master Valve/Pump. If you have one, connect to βMβ and it needs to be configured in your app
- zone 8 β 8
- zone 7 β 7
- zone 6 β 6
- zone 5 β 5
- zone 4 β 4
- zone 3 β 3
- zone 2 β 2
- zone 1 β 1
I have a question about replacing my Rainbird ESP-8SI to a Rachio 3, my current system is a 8 zone and the Rachio is a 8 zone. I want to make sure that this will be a smooth replacement.
Would anyone mind looking at the pictures and seeing if everything looks good for the transition?
Others have changed their Rainbird ESP-8Si over to Rachio 3 without issues (Rainbird ESP-8SI to Rachio 3 Wiring - Troubleshooting - Rachio Community). You would use Rachioβs power supply instead of the Rainbird and the rest of the wires are simple. I would suggest making sure everything is working if at all possible before disconnecting, take pictures and/or label wires, and bring them over. COM β C, MV (if any) β M (if have, need to enable in app), 1-8 β 1-8.
Thank you @Thomas_Lerman! I thought it looked straight forward but measure twice cut once and ask for anothers view always helps ![]()
Appreciate your help!
No problem, we are glad to help. I agree on the measure twice, cut once.
