Rachio 3 Not Responding in Homekit (Again)
@alexrodriguez you are correct. I logged into the WebUI for my unifi controller and this option is NOT visible there. It is only visible via the IOS app.
As an update…we had big storms last night and everything lost power. Rachio came back online with no manual intervention and is working in HomeKit. So this setting DTIM=1 either directly on the AP’s or via that IOT unifi setting, definitely overcomes the challenges in the rachio implementation…but rachio does need to get this update out the door. The science experiment of getting this to work has been like getting really awesome at changing a spare tire…
Its probably overkill but my home hub (atv) now also has a DHCP reservation in the unifi controller also.
Thanks for the updates, @dane
As we can’t comment any updates in the updates forum I’m copying it over here so we can comment on it.
I’m actually getting hopeful.
I’ve finally got mine working to the point of not having to add it back in, but it still drops off of HomeKit but fixes itself now.
I do hope they share with us what the problem was.
daneCS Manager @ Rachio
1h
08/06/2021 Update
Incorporating a new Apple Development Kit (5.3) into the firmware. The Apple engineering team is recommending this as it might correct the disconnect issues customers are experiencing.
That sounds promising
Can you share what you may have done different to get yours working?
I attribute my successful Rachio HomeKit connection to my Synology AC 2600 mesh router. The only thing special I have done out of the box is assign a high priority to the Rachio. Rachio connects to both 2.4 and 5GHz networks. It never drops and always reconnects after power failures etc.… Has been rocksolid for the past year. Everything on my network started working better with Synology after retiring my Apple router.
I have a ubiquiti UniFi mesh network.
How can I get the old firmware? Just bought Rachio but it’s a 2019
And oddly mine has been rock solid every since I turned off IP6 in my gateway.
I’m still using five old Airport basestaions all hard wired to my gateway.
@dane
well…I thought it was past all of this. For no reason at all my Rachio just did the “no response” in homekit and now im back to square one. Wont add in, cant find it to manually add it.
No settings were changed…just the day of the week.
Hi @Tzterri I want to let you know that we will share a high level root cause of the HK issue once we have completed our investigation. We do not want to speculate the cause of the issue until we have successfully resolved
Need to get more resources to fix this issue. 10+ months in in beta testing and yet to see anything remotely fixed (been sitting 2 months with the beta, can’t even add Rachio to home kit. Doesn’t find it when manually entering code. Emailed people on how to fix it, nothing. So can’t really even contribute to this beta testing). Complete mess
Dane, this is great news. Thank you. For those of us that participated in the previous beta, and still have the beta firmware that doesn’t work at all, will you guys be able to push the updated firmware to us? (when you figure out a fix)
So you are saying that yours is still working ok? Please check in. Also, please submit this thread to Guiness World Records for longest ongoing dialog on a technical issue.
On behalf of @Macsterguy everything is perfect! His Rachio and HomeKit live in virtual nirvana.
Don’t forget me :grin:
Mine added to HomeKit and stayed connected to it, flawlessly, for the month I had them connected. (I’ve since removed all accessories from HomeKit, deleted the Home instance, and moved the iPhone/iPad app off to a corner. Even had I kept using HomeKit, I didn’t find the Rachio 3 being added particularly useful.)
In all this noise, what some of y’all have failed to notice is that, for something y’all seem to think is so common, it appears to have taken Apple’s people three weeks to replicate. (Based on the date at which Rachio announced Apple’s people were looking into it and the date it was announced they’d finally managed to replicate the problem.) IOW: Apple’s people had to work at it to get it to fail.
:roll_eyes:
That assumes a lot from Apple’s team. Your point is made though. I really doubt they worked at it for three weeks. But the key thing is, they observed the issue and most certainly captured it in logging. It is a real issue. And is part of the product we expect. I for one am looking forward to seeing this resolved, and not having a Homebridge dependency. (Although I have since added four more products to homebridge so now i guess I am stuck).
By the way, I have many automations that I am able to leverage with this working that the rachio app and schedules would not have permitted. So for everyone that thinks this is not needed, just be aware, there are environments that have some complexity and capability.
Hi all, i am part of the beta and rachio on homekit has been working great but now it’s back to Not Responding…. Is this affecting any of you as well?
No such problem here, and I am on the beta, as well. Just turned on Zone 1 at home, while I am at work, using the Home app on my Mac.
