My master valve is also a zone?! Is this right?
I think I just discovered the problem as to why zone 3 runs with every other zone: it appears to be the master valve.
Even with the Rachio control panel unplugged from power, when I manually twist the solinoid on any zone the zone will not run unless I have zone 3 manually twisted to the “on” position.
My question is how in the world would I make it so that zone 3 doesn’t run with the other zones? It’s overwatering that area tremendously. Was this an original design mistake? Or, perhaps a part is malfunctioning?
This problem originally was reported here:
After months of stalling, and line detector rental, cleaning out valves, etc. I just discovered that even with the power off the other zones wouldn’t run without my zone3 solenoid being manually turned to the on position.
I guess temporarily I could manually disable all the sprinkler heads in this zone, right?
I had similar problems. Turned out that the rubber membrane in the valve was to old. After replacing it with a new valve problem solved.
is a master valve physically and mechanically different from a regular valve?
I am a new user, zone 1 runs for a few seconds each time I run a diff zone… could this be why??
