Connecting Hydro-Rain HRC-100 Wireless Rain Sensor to Gen2
#1
The builder of our home installed a Hydro-Rain HRC-100 Wireless Rain/Freeze Sensor connected to a Hydro-Rain HRC-100 C Irrigation Controller. The Sensor (Photo 1) is apparently powered by two 24VAC OUT terminals in the IC (Photo 2). I just purchased a 16 zone Gen2, and want to find out whether the existing HRC-100 sensor is compatible, and if so, how do I wire it to the Gen2, and program it. If it is not compatible, what is the best wireless Rain/Freeze sensor that you would recommend that is compatible with the Gen2?
Photo 1
Photo 2
#2
@joephoto, thanks for reaching out and joining the Rachio community.
Wireless rain sensors have to double up a wire on the “SC” terminal in Gen2 – this support article has a good visual to reference.
For the Hydro-Rain HRC-100 Wireless Rain/Freeze Sensor, I’d recommend the following wiring setup:
Red 1 - SC
Red 2 - SP
White - SC
Yellow - S1
Don’t forget to enable your rain sensor after wiring it up. The support article above references the steps to do so :wink:
Hope this helps.
Best, Emil
#3
@emil you rock.
Thanks for the quick response @emil!
#5
You’re very welcome @joephoto. Let me know if you run into any issues with this wiring.
split this topic #6
A post was split to a new topic: Connecting Hydro-Rain HRC-100 Wireless Rain Sensor to Gen3
