App not showing PWS
How do you get your personal weather station to show up in the App. I have it integrated to Weather Underground and has been for over 2 years but does not seem to show up in the app when attempting to integrate it. Thanks
I asked here but got no answers.
Really odd, my personal weather station is showing (Weather Underground) Are you using your Weather Underground station ID to add? You should be able to see it when you select “Weather Stations” Use Personal and you should see your station. One thing to verify is your address in Weather Underground should show your home address and it should be the same address as your Rachio controller. I have my station set up and it did show up as a station to select and add.
Thank you for taking the time to reply. I can see the other weather stations in my area but not mine. I verified that the address is correct.
I was reading on similar post from others in July and the Rachio support team reached out to the Weather Underground support to have the API updated to resolve the issue. I am just unsure what the process would be to have that completed.
