I’m writing my own scheduling mechanism and I’m trying to figure out soil moisture percentage so I can determine if a zone needs watering.
I was only able to come across one other occurrence of this topic within the Rachio Community but it is archived and does not answer the question:
https://community.rachio.com/t/accessing-and-modifying-moisture-levels-via-the-api/5288
It’s also a little bit on the older side so perhaps the response has changed.
Here is a zone we can discuss:
"zones": [
"id": "obfuscated",
"zoneNumber": 1,
"name": "Z1: Side Northwest",
"enabled": true,
"customNozzle": {
"name": "ROTARY_NOZZLE",
"inchesPerHour": 0.47
"customSoil": {
"name": "SANDY_LOAM"
"customSlope": {
"name": "ZERO_THREE",
"sortOrder": 0
"customCrop": {
"name": "Warm Season Grass",
"coefficient": 0.6499999761581421
"customShade": {
"name": "LOTS_OF_SUN"
"availableWater": 0.11999999731779099,
"rootZoneDepth": 10.0,
"managementAllowedDepletion": 0.5,
"efficiency": 0.800000011920929,
"yardAreaSquareFeet": 800,
"imageUrl": "obfuscated",
"lastWateredDuration": 702,
"lastWateredDate": 1563021000000,
"scheduleDataModified": false,
"fixedRuntime": 0,
"runtimeNoMultiplier": 5222,
"wateringAdjustmentRuntimes": {
"1": 7834,
"2": 6528,
"3": 5222,
"4": 3917,
"5": 2611
"saturatedDepthOfWater": 0.66,
"depthOfWater": 0.6,
"maxRuntime": 10800,
"runtime": 5222
In the Rachio smartphone app, it says this zone has 53% soil moisture at the time of writing. I don’t see any obvious way to come to that conclusion with the above data.
How do I calculate soil moisture percent?
