All Weather Underground PWS Stations are gone
Suddenly, I can no longer see any Weather Underground PWS stations.
I have disabled and re-enabled the GPS on my phone, rebooted it, tried in another device, and the same problem. This is not a user problem but a System problem.
Also, I can access the WU page and look for all those PWS stations just fine, so they are there and online, but can’t longer see them on Rachio Weather Sources
Anyone having the same issue?
I am having a similar problem, with most likely the same root cause. Specifically, in the Rachio app (iOS version 4.21.8):
Settings → Weather source → Weather station → CHANGE STATION → PERSONAL
shows only a very small subset of the Personal Weather Stations (PWS) that were previously displayed.
For example, the previous 10 closest PWS were all within about a mile of my home. Now the closest is about 1.5 miles. When I click on “MORE INFO” for this PWS, it opens up the station’s Weather Underground (WU) page in the Rachio app. What is interesting is that the map on the WU page shows all of the “missing” PWS that used to be selectable from within the Rachio app, but are no longer listed.
I still see a total of 10 PWS within the Rachio app to select from, but they are all much further away. I couldn’t identify any pattern or logic as to how the PWS are being filtered or otherwise limited in the current release (e.g., specific manufacturer, only “gold star” stations, etc.).
I am having and have reported the same issue; the stations listed are pretty random and there is no rhyme or reason. I have a Davis station reporting through Meteobridge since 20 years and on WU, CWOP, APRS, WeatherLink etc. It is disappointing to see the loss of many stations. If you compare the stations listed on the WU map and what Rachio has it is indeed 3 miles away, whereas I have six stations within a few houses. This points to a API issue where Rachio is getting bad info from WU’s API. When reaching out I get within minutes a lengthy AI bot response that does not adress the issue and confounds Aeris weather into the topic. Looks like a FUBAR SNAFU on Rachio end with no human watching.
Cross posting here:
Now, today the closest weather station is an airport 11 miles away. Stations that were still there yesterday are all gone. This is all garbage and a clusterf at Rachio’s doing. I exchanged several emails with ever more stupid non-technical “solutions” and explanations.
I think they are lost and that whole functionality is gone, which effectively makes the station a remote controllable irrigation controller like any other. The enshitification of smart devices. It lasted for a year. No useable customer support.
Hi,
And today suddenly neither National nor Personal Stations are loading. All I am getting today is a blank list :-1:
Not sure what is going on but it’s getting worse. Hope this is has nothing to do or has all to do with the Rainbird acquiring Rachio :-/
Seems to be representing all WU stations back on the WU API and thus also on the Rachio map. Will monitor if this changes (as it has several times in the last weeks.
