On one of my systems, I have 3 zones running through my Rachio. We had to do some work in my yard and we added a 4th zone, but it is too far to wire into the Rachio. The real problem is, there is no way to go through the concrete (so the distance isn’t too bad). Is there any type of wireless relay or something that will allow me to tie that zone into the Rachio without a direct line?
@dcent44 - a zone wire can be run at least 850 feet. See →
Curious what kind of distance you have to go, both going around the concrete and going under? If you were able to go under the concrete, how much concrete and do you have access to both entry & exit points? Is there power or anything by where the 4th zone would be? What about other valves?
