Zone fault error
Still getting the Zone Fault error. When it happens the timer and app say it’s running but the pump does start. So I don’t know if I have actually watered unless I’m awake.
Often times. I find it’s a mill amps problem. Wire cuts, bad solenoid
Rachio can test your zones, and you can compare, often found replacing solenoid makes the difference.
Good luck.!:grinning:
