Thought I would check here to see if anyone else has had this problem before I contact support.
I have been checking two of my drip lines for leaks and have been running them using Quick Run at the 10 minute mark. Thought they were all fixed, but when running my Flex Daily schedule one of my zones (the first one in the schedule) had a bad leak and I stopped the schedule for that day. Then today when it went to start for the second zone I happened to be at my phone and saw that the zone was only going to run for 10 minutes. Looked at the zone, and sure enough, the duration was set for 10 minutes, when it should be an hour and 14 minutes!!! I have not made changes to any my zones since 2022 (per the spreadsheet where I keep track of all zone changes). Somehow, it changed the duration to what I had been using for my quick runs. Only the one zone did this, the other one is fine. My app on my iPhone is up to date and that’s where I’ve been doing the Quick Runs.
Looking at the history, I can see that the schedule, before I stopped it, had both zones correct. I stopped it while zone 9 was running. That zone was still set with a correct duration. But the zone 10 that follows it was now set to 10 minutes.
Has any one else experienced this?
