I have one zone that will only water 1-2 minutes per week no matter how I set up the zone. I’ve tried changing the soil type, plant type, emitter type, water depletion, you name it. Always the same result. I’m at my wits end with this thing. What can I do?
You might have manually adjusted the time down in the schedule. I’d delete the schedule and start over.
Thank you. I deleted the original schedule and created a new one. Problem solved. ![]()
