Hello,
We got quite some rain the last two days but it seems the calculation for the moisture balance is not correct (July 7):
Can someone please explain? Or am I reading the data wrong?
Thank you.
Nora
Hello,
Thank you.
Nora
My understanding is that moisture balance is limited to 110%.
Hi Nora-
@ldslaron is correct, we do cap your moisture level to 110%. A lot of the excess water above that is lost below your root zone or is not able to be absorbed by your soil because it has reached saturation. If you need to, you can manually “fill” your zone if you feel like it is still saturated but your moisture graphs are reading low!
McKynzee
