Hello I am going from a hunter to the rachio. I have gotten the ringing moved over but on my hunter the red and black sen wires were hooked up and on the rachio I don’t see where they would go. Any help is appreciated. I uploaded picture above.
Thank you
I would suggest not hooking up the sensor yet. Many find they do not need or want the sensor with the Rachio. Are the red & black both sensor wires? I do not see the power hooked up to the Rachio yet. You certainly can hook the wire common wires together like that, but I would recommend putting them on separate terminals.
