Hi,
I finally got my wireless flow meter installed. However, when I try to add it to the app, it’s asking for a barcode or serial number? I can’t find either on the flow meter and I don’t have the box any longer (my plumber threw it out). How can I setup the meter?
The barcode is located inside the wireless flow meter (WFM). You will need to remove the battery cover on the WFM to access it.
I removed the battery cover and looked all over and still didn’t see anything. I pulled out the battery holder as well and looked at the back of the cover… nothing… :-(. I bought this flow meter as part of the pre-launch program for the Rachio3… I only just installed the Rachio3 and the flow meter this season.
It would be a tag within the battery compartment that should be covering the batteries.
@franz, @laura.bauman, @Gene, or any other Power Users, thoughts??
Wow, it sure is missing.
Hopefully @franz can have his Rachio tech experts help you with this problem.
My serial was included within the battery compartment as a semi loose sticker with a waxy glue protection paper still attached. I’m sorry to see that yours is missing. This seems to be a case for @rachiosupport.
Dang that’s no good. Please reach out to https://support.rachio.com. They will get you setup.
Thank you for your patience and have a great day.
Hi Franz, I did… I have a case open but no one is responding to it… I just checked the app but I can’t seem to find a ticket number to give you…
Hi! I still haven’t heard from support…
@franz Hi Franz, can you poke support for me? They still haven’t responded to my case.
