@Linus, use a shovel and like @Gene, said earlier, follow the direction of the pipe and just stab the shovel through the grass and you will probably find the valve box covered by grass. It is most likely in line with that main pipe and not very far away. Often times spare wires are run back to the controller but just wire nutted and not hooked up.
. . . and be careful of the pipes and wires.
