I want to limit the access to the only open port in my router’s firewall. For Home Assistant to sync states with Rachio, Webhooks are needed. Everything used to work when access was limited to IP addresses 52.43.140.238 and 34.208.216.98, but it looks like Rachio calls come from a different IP now.
Is this documented somewhere? Maybe someone has been able to determine the IPs used by Rachio to communicate with API integrations. The idea of leaving a port totally open to any “from” address does not sound safe at all… Thanks!
