I plan to buy a Rachio 3, 12-station controller (apparently only sold through CostCo). Can someone please confirm if it will fit in the optional Rachio enclosure weatherproof enclosure?
Thank you kindly.
Thank you kindly.
@kitjv - yes it will. The only difference in the 8, 12 and 16 station controllers are the number of terminals. The size of the unit is the same. As a heads up, don’t put the magnetic face plate on the unit when installing it inside the waterproof enclosure (it is mentioned in the instructions):
DLane, thank you so much.
