I can’t figure out why I am only given the options to skip for wind and freezing? Last season I had an option to skip rain as well?
there is no rain skip in flex daily. Flex daily works by using weather data to determine when your root zone is depleted of water, and that is the trigger to water each zone. If you get precipitation, the calculated water levels are adjusted, and the watering is delayed until it is really needed.
Click on a zone, then click on the soil moisture item to see how rachio is tracking the moisture level for that zone. Your Rachio app or web interface will show you when it expects to water each zone that is on daily flex.
Perhaps the rain skip option was for a different schedule type, such as monthly flex.
