I have two controllers on the same account a thousand miles apart. How come the app only shows the same Weather Intelligence Plus display on both controllers? The map in the module shows the correct location. I would think that the daily weather would be different since one is in the dessert and one is on the coast. Your thoughts?
Make sure you are picking up the correct weather stations. If you select a PWS station, it will use that for rainfall, and use a NWS/NOAA station for ET calculations. If you’ve picked a PWS, continue down to see which NWS station it has selected.
