Hello,
I am trying to set up a schedule for the watering of a parking strip which is 3’ x 30’
As I set up the schedule it is telling me that the watering duration and total time will be 31 minutes. Is this the daily amount of time or the weekly. If it is daily I’m going to be flooded.
What type of schedule? Zone settings?
The only way it would be daily is if you specified a Fixed schedule and had it water daily. For Flex Daily it will water when the moisture gets low enough, this time of year, probably every 4 days or more. Pretty much the same with Flex Monthly. Your schedule will tell you when it will water next, so you can tell from it.
