Water on End Date?
Okay, with a Fixed schedule, I can specify a Start Date and an End Date. Assuming the schedule is set to water every day, is it possible to water only ONE day. That is Water just March 30. I can set March 30 as the Start date, but cannot enter March 30 as the End Date. And if I enter March 31 as the End date (the minimum), the Rachio Upcoming says it will water BOTH March 30 and 31.
It seems really funny to me that it can’t be set to only water 1 day using start and end dates. I guess a workaround could be to set it to only water every 2+ days, but that really doesn’t explain the operation. If an END date is the last day that the system will water, then the system should allow us to enter the same date for both START and END, to water one day.
