The Schedule is every day except Monday. The morning watering is for 28 minutes. The evening watering is for 23 minutes.
Schedule randomly shows 2 waterings instead of 2 every day except Mondays. June 8th weather is forecasting rain, so calendar shows no watering.
I have a feeling you’re not using a fixed schedule but rather one of the flex schedules. Also the times (durations) for each of your zones seem extremely short. Mine as an example run for 25 minutes per zone. Is that just because it’s sand??
Yes the first schedule is on point, however your second schedule is using flex daily and not fixed. That is the issue you’re seeing of why that doesn’t water consistently the way you want it. Change that to a fixed schedule. Also set the second schedule to a different color so that you can see them more clearly on the calendar
Thank you very much. The calendar now shows two waterings a day for the full month, except Mondays. Really appreciate your help.
Can I get added to the Beta? This is a feature I miss greatly.
FYI This feature has since disappeared for iOS beta.
Well that is dissapointing
