done (link), be on the lookout for PWS_KNCCATAW11 within a few hours.
Cheers,
Gene
Cheers,
Gene
Awesome! Thanks, Gene!
Hi Gene,
Wondering if you could be so kind as to add mine as well?
https://www.wunderground.com/personal-weather-station/dashboard?ID=IBUNDANO8 or https://smartweather.weatherflow.com/station/4602/grid
Thank you in advance
Hi @Gene Will this still work with the changes coming to the WU api ? Thanks!
@efleming done (link), used WU, but made a note of your Weatherflow station ID in case we ever need it as a backup.
@mda for now WU support is working, though there is support for alternative data sources as much as possible (such as AcuRite, WeatherFlow, Ambientweather to name a few).
Cheers,
Gene
Thanks @Gene my weatherflow is https://smartweather.weatherflow.com/station/5767/grid (I am running Rachio v1s)
@mda Can you please double check that your data is shared publicly, more info on this here (link).
Thanks,
Gene
it is shared. does this link work? https://smartweather.weatherflow.com/share/5767
@mda Yep, data is now available via pwsweather here (link), you should see it within Rachio interface under PWS_WF5767 in a couple of hours.
Cheers,
Gene
Hi Gene. Getting ready for spring startup and would like to switch to my weatherflow station for Rachio v2 input. Could you please link my data to PWS?
Weatherflow:
or WU:
https://www.wunderground.com/dashboard/pws/KVARIVER2
Thanks,
Doug
@doug-h done (link), used WU for now but we can always switch over to weather-flow later on.
Gene
All set. Thanks for the rapid reply and assistance!
@Gene Could I trouble you for a link also?
Here is our WU url: https://www.wunderground.com/dashboard/pws/KTNLEOMA5
Thank you!
I now prefer to use alternative sources, if possible, instead of weather underground (fewer problems this way)
Can you make sure your station shares data, and send me (link) your share url which starts with
https://smartweather.weatherflow.com/share/…
If not, we can still use your weather underground station, just let me know your preference.
Here it is @Gene :
https://smartweather.weatherflow.com/share/6809
Did my weatherflow link work okay?
Yes, sorry I was having issues with the auto registration code for pwsweather. Working on it now.
Should be up and running in an hour or two, just verifying that everything works as it should.
@Rrmajiros Done (link), be on the lookout for PWS_Wx84831, better late than never
Thank you! Much appreciated!
