Hi, our house is right beside a canal in South Africa and therefore we use the canal water for watering.
However the problem is that there are times, especially in the winter months when the canal is emptied to do repairs and cleaning. My question is if there is possibly a solution to stop my rachio from watering these days without me constantly having to do rain delays in the app.
We do get a schedule at the start of the month when the canal is scheduled to be stopped and I do have Home Assistant set up in my home. But I do not know if I should go the schedule programming path or rather install a physical sensor somewhere.
I do have a water detection sensor in my pump which auto turns it off when no water is in the pipe, however this causes the pump to turn off when normally trying to turn on irrigation with the canal full. Therefore I would like to uninstall this, but would then like a other method to do this automation.
TL:DR - I am looking for a way to automate my rachio to not water when the canal outside our house is empty. We do have Home Assistant and we do get a schedule of when the canal is empty and I do have a water detection sensor at the pump, but this is malfunctioning and is probably going to be uninstalled.
Any help will be greatly appreciated!
