Is there an API to perform a Quick Run?
where I can turn on a Zone, set the Duration and Run
OR
A way to start a schedule then come back and stop that schedule.
I would just make one long schedule and us the API to shut the Schedule off later when it’s been on enough.
I don’t think the API will accept longer than 3 hours for a zone, but you could create a schedule for the duration you need and disable it in the app, then call /public/schedulerule/start from the API and it should work.
I was thinking of making say 9 schedules.
Each schedule with different durations, like 1 hour, 2 hours, etc…9 hours.
Then just start the schedule I want based on the the duration I want.
Would that concept work…?
How can I get the ID’s of all Schedules in the System?
Then call the following API to start the Schedule I want
and call the following API if I have to prematurely stop the scheduel:
Thank you for your time Brg468.
Lastly
is there a public server where I can test this API
that has some zones and schedules on it.
To Try the API and get some JSON back.
