System not working but App is
Q 1 - Has anything changed to your system since it last worked?
Q 2 - Do you have a master valve or pump relay that isn’t wired up?
Q 3 - Is this happening on ALL 6 zones?
I would suggest going to the valve box and turning the screw/knob on the solenoid to manually test activate the zones that are not working.
If the head(s) pop up in those zones when the solenoid is activated, then its bad wiring from that solenoid to the controller.
If it doesn’t pop up, then you need to backtrack and check to see if your water supply for the sprinklers is turned on at the backflow preventer (if you have one).
