I replaced 3 Toro valves with an Orbit three valve manifold. Same wiring to the new solenoids, but Rachio 3 will not turn the valves on. When I move the wires to an orbit controller, they do turn on. Is there a voltage difference or other current problem? Do I need to reset? Thanks!
@dvmtbm - can the model number of both valves or the solenoids in the valves be posted?
Do you have access to a multi-meter to test voltage and resistance?
