Twice, I did a quick run on a disabled zone, had the zone run for the allotted time, had it turn off, then found it running again a while later. Worse, I went on the app to see how to turn it back off, or see why it started running again in the first place, and could do nothing with the app or zone. The zone showed it was disabled, it showed nothing about it running, and the usage doesn’t register either. I couldn’t find any way to see what started the zone or what could stop it.
I had to stop things by manually shutting off the valve to the zone. A few minutes later, when I opened the valve again, all was well - - no water running to the zone.
This only happens on one zone, so far.
Any clues why this is happening, and how to avoid it? I’d hate to have this go on - - and on and on and on - - when I 'm not around.
