In my one Zone there are Sprinkler as well as Drip lines. When I run Zone-1, both Sprinkler and drip line runs. I see that Drip line has Percip rate of 1.44 in/hr and for sprinkler its 59.53 in/hr. How do i schedule watering for such Mix system?
First off, I think you need to double check your sprinkler precipitation rate (inches per hour). That is an unobtainable high PR for a sprinkler.
Otherwise, it is incredibly tough to set a zone up like this correctly. The PR and watering needs of the plants are SO different.
What sprinkler nozzles do you have? Is it a lawn sprinkler? If so, is it a rotor, or pop up spray head?
