I’ve opened a support ticket, thanks for the nudge.
Damn, I knew you would ask
First fill this form out.
http://www.findu.com/citizenweather/cw_form.html
You will get an email asking you to verify your station location. Once verified, send the verification here.
Once you’ve verified your location on the findu maps or aerial photos,
send a message to
cwop-support@noaa.gov
I then received a response as such:
Hi ,
Thanks for sending the data and checking your location. I’ve attached your
station information to the APRSWXNETStation.txt that controls things. That
file will be loaded under item 2 on this page sometime later today,
http://www.wxqa.com/memberlists.html
Or after the 0000 UTC update, you can use the CWOP Search Tool to search the
member lists,
http://www.wxqa.com/search.htm
Look over your entry and make sure that I have things the way you want.
Latitude and longitude is in decimal degrees and elevation is in meters. The
APRS format can locate to within about 20 meters. If you readjust the
lat/long numbers, be sure and tell me so I can update the CWOP database which
is different from the findu database.
Your data should show up on MADIS and the NOAA mesonet map web page after 2200 UTC
on Wednesday 3-Aug-2016.
I remember it taking about a week to start showing up on my weather station map in our app.
Note the two identical stations at the top, one PWS, one CWOP
