When I go into the app, i attempt to select any of my smart hose timers a message is displayed: “Sync in progress. Please try again in one minute” this has been occuring for 2 days.
When I’m on the Home screen, all 4 valves show, but the last one has status of ‘Busy’.
How do I reset this?
I’m having the same problem. But power cycling the hub does not fix it. Anyone else have any other solutions? I have also tried power cycling the hose timers themselves (by taking out the batteries and reinstalling)
I just deleted and added back in, to get it working again. Perhaps you can still tell me what the next step would have been (if different than that), in case it happens again.
Power cycling the hub appears to have worked this time. Let me see if that sticks this time before resorting to replacement. Appreciate the offer of that for sure.
I deleted my Home (which included the Hub and two Hose Valves. I re-connected the Hub to the WiFi network and added both Hose Valves. This time, both valves received a firmware update (even though the version number seems to be the same–3.0.52–after the firmware update). And, so far, the issue is resolved.
@brochner Ok great, thank you for this update. We have a new firmware update that we will have available soon that will address this issue as well as other enhancements.
I have the same problem. Smart home timer shows busy, won’t turn on., says “syncing try again in one minute” won’t work, reset hub, won’t work, reinstalled the app, won’t work…I have to manually turn it on with the button at the hose.
I have the same issue. Four timers are all “busy” even after resetting up and timers. I have already reset them all a few weeks ago, and now it’s happening again. I don’t think they were running this week. After the latest restart they all are labeled disconnected.
