Smart hose timer API requests
@franz or @dane, is there a preferred channel to request modifications/improvements to the smart hose timer API? I’ve mentioned a couple on a different thread, but I’m not sure that’s the most effective place for requests. Thanks
You can do here, just tag me so I see it and I can review with the product and engineering team.
Thanks @franz!
Ill post a couple now that have come up…
  • The ability to enable/disable a hose timer schedule through the API. The current method of finding and skipping individual runs is ok, but also kind of a pain. Would it be possible to add enable/disable schedule, or even make the createSkipOverride endpoint act like its delete counterpart where not providing a timestamp would skip all upcoming runs, or just the next run. Or something like the rain delay on the controller…
  • Webhook support would be real nice, probably for your servers as well as us users.
  • Add the name assigned to the base station, which I guess would involve assiging a name to the base station. At a minimum it would be nice to know what “home” the base is assigned to for origizational purposes. Right now the only identifier is by the address, but for privacy I could see people not wanting to include that in 3rd party systems.
  • The name “lastWateringAction” is kind of misleading as it’s esstially current watering action, but that’s not a huge deal once you figure out what it means.
Thats all I can come up with at the moment, I’m sure I (or someone else) will come up with more :grinning:
Thank you for posting @Brg468 . I’ll make sure the engineering and product team reviews these.
Another request/question…
On the getValveDayViews endpoint, schedule info is present before and after an event, but disappears while the event is actually active. Is that intentional? I would think once it starts the event is now in the past. It makes keeping track of events trickier when it goes away temporarily.
@Brg468 Hi, did you find an API that works with the Hose timer found at:
Hose TImer
Whenever I use my API key on the postman samples, e.g. https://api.rach.io/1/public/person/{{myUserId}} my devices come up emtpy. e.g.:
{"createDate":1741737848000,"id":"xxxxxxxx-9440-00x0-9d6e-xxxxxxxx","usernam
e":"xxxxxxx@xxxxxx.com","fullName":"Xxxxxxxx Xxxxxxxx","email":"xxxxxxx@xxxxxxxx.com","devices":[],"deleted":false}
Thanks,
Ernest
Yes the Hose Timer is hosted at https://cloud-rest.rach.io.
The readme is here Welcome
@franz, did you guys intentionally remove the address and locality items from the base station info? Just noticed its not there and is throwing a KeyError now in HomeAssistant. Not a big deal if its gone but just wanted to check before I removed it from HA.
@Brg468 We will expose that endpoint data in our documentation. I will let you know when that is published.
@Brg468
The team has updated the documentation
