OK, purchased a Rachio 3 “SMART” Sprinkler Controller, was looking at how to setup simultaneous zone operation, couldn’t see any options in the app, so I searched google. You can probably imagine the disappointment I had when the google search led me to the forum where I am reading that Simultaneous Zone operation is not available on the Rachio 3 “SMART” Sprinkler Controller. So I’m thinking to myself maybe it’s called something else because surely a “SMART” Sprinkler Controller (as Rachio refers) should have a very simple feature that all of my old “DUMB” Sprinkler Controllers have had, but after further searching the forum and reading posts from 2015 thru Aug 2023 it does not seem to be an option. The interesting part is there have been multiple requests over an 8 year period with what seems to be no movement. It’s really a simple feature to add in the software.
My Two Use Cases:
My system pumps from our lake, each of the zones are sized fairly well except our drip zone, the drip zone causes high pressure, so we have always ran is Simultaneously with one of the smaller zones in the system. First thing that comes to mind, wire them together, but the drip zone usually doesn’t need to run as long as any other zone during the summer, so it needs to be on its own zone with its own adjustable time.
Few years back I installed a fertilizer injection system that I decided to add its own valve because it doesn’t need to run each day for the full time of watering, so it was placed on its own zone so it could be adjusted and ran with the other zones as needed. I’ll admit this feature wasn’t as easy to implement with other controllers but I ended up setting up a schedule to run each zone for a short period of time and the fertilizer zone would be timed to be on the whole run time across all of the zones. Once that condensed fertilized watering session was complete, a second schedule would run after to extend the watering time for each zone.
Both cases I was able to accomplish with other “DUMB” residential irrigation controllers
If I am wrong and this option does exist, could someone please point me in the right direction to setup?
If I am correct, I will be very disappointed that such a simple feature that “DUMB” controllers offer is not offered on such a “SMART” controller.
You are in a small minority where you have a situation where you have some headroom on at least some of your zones. While I can’t speak to the original decision to not allow simultanious zone running, I suspect it had something to do with making sure a homeowner didn’t unknowingly overlap schedules and have performance issues in the system.
For the sake of your drip system, they have pressure regulators designed specifically for this purpose. Could style, with and without filter (might be good insurance since pulling from lake).
I’d like to second the disappointment at a lack of simultaneous zones considering dumb controllers have had this ability for many years. I’d expect a smart controller to at least have feature parity with those. My parents have the pressure and flow to run a few pairs of zones simultaneously and now my dad is having to double up wiring those zones and then rewire for winterization blowout. Would be nice if this was at least a hidden advanced feature.
Created an account purely to add a vote for this. My Irritrol Rain Dial handled this just fine - I replaced it with the expectation that switching to Rachio would make watering more efficient, but frankly this is a gigantic PITA and making me rethink my decision. It honestly didn’t even occur to me to consider that Rachio would not support/permit simultaneous zone operation. After all, the Rain Dial handled my 6-zone setup just fine, no pressure issues.
I get the pressure argument, but frankly that’s not Rachio’s call to make – it’s my call as the end user. Having a default setting of sequential, with the option to switch to simultaneous, would be a much more reasonable way to handle this.
I have done away with Rachio due to the lack of certain smart features like simultaneous zones. I have also recommended to my friends and neighbors to go with a different brand of controller because this one isn’t very smart and flexible. Definitely geared towards the simple system.
I do have pressure regulator for the drip, but when using a pump, I would prefer not to limit the flow and produce addition strain on the pump, when there is a simple solution of running simultaneously with another zone.
