Hi! I know you can set a zone’s moisture level to Zero force a watering with the flex schedule but is there a way to set a specific moisture level. For example if you feel the zone is pretty damp but the moisture level is showing a low percentage can you manually enter a moisture level? Thanks!
I asked this same question to technical support on phone last week. The answer is “no”. For now, the only options are to use the Empty (MAD %) or Fill (100%) buttons.
          Thanks for the answer. I didn’t think there was a way but wasn’t sure if I was missing something.
You can always start a manual run to fill the zone, then set it to 100%
