I have a drip system in my back yard set up as one zone but one area is really wet and needs less water. It is on a separate line. How do I make it two zones on my Rachio?
You contradict yourself here a bit…
If it is multiple zones set up on one schedule, then you can adjust the zones within that schedule accordingly and back down the watering on the wet area.
If in fact this is one zone, you’d have to re-pipe the zone with two separate valves. No way to do it on the controller side alone.
