My saturation level percentage for each zone on longer shows. I’m running flex daily
Moisture level? Can you post a screen shot? If you are running Flex Daily, it should show a moisture percentage.
Does it show if you go into the actual zone?
No but I had flex month on not flex daily. When I changed it, it worked fine. Thanks
John Selvaggio
Flex Daily is the only schedule type that will show a moisture level.
