we should be able to see the saturation numbers that rachio is using when it skips and the history under fixed schedules just like the other options. I get a skip which is great but why not make the saturation numbers visible just like on daily flex?
Probably because people would be upset when the graph inches further and further below zero, or stays near 100% all the time, never approaching the bottom of the graph, which is what would happen if not tuned perfectly. They’d complain that Rachio “knows” the moisture level, yet isn’t responding to it. And if tuned well, it would be far better to use Flex Daily.
And even if tuned perfectly, the graph will show the results of higher and lower than normal temperatures. If you believe the graph, you really need to believe in Flex Daily, IMHO.
