I have 12 zones and pump my water. In the spring I have enough pressure to run two zones at a time, but at the end of the summer when the water is lower, I can only run one zone at a time. Can the Rachio 3 controller run two zones at the same time in any order? For example spring time settings running zones 2 & 11, 9 & 7, 4 & 12 and so on… Then at the end of summer revert back to one zone at a time running zones 1, 2, 3, 4 and so on…
Thanks,
John
