I added a Rachio 3 in place of the existing Rachio 2. The Rachio 3 is working perfectly, but the Rachio 2 is still showing up in the app.
Two questions:
- How do I remove the Rachio 2?
- By removing the Rachio 2, I want to keep the legacy configuration and pictures intact for the Rachio 3?
Thanks in advance!
If you need to delete a controller manually you can do so through the more tab simply ensure the controller that you want to delete shows at the very top then select controller settings > Remove controller > check the box > press remove
To confirm the controller has been deleted be sure to log out of your account then log back in.
Hope this help
This worked perfectly. Thank you kindly!
