Recommended Watering Duration always 3 mins
I live in the Netherlands and am using Rachio since many years but I completely re-did my garden with 8 zones and now need to refine my setup.
Am using a flowmeter so know exactly the water usage per zone.
I like to use Daily Flex schedules again but no matter what i do the recommended watering duration is 3 min. See screenshots.
Via another post I found that Rachio doesn’t support Canada and that’s why the recommended watering duration isn’t calculated corrected. Am assuming Rachio also doesn’t support the Netherlands;-(
If I change my location to a comparable climate location in USA (Portland ORE) Rachio recommended 1 hr + 45mins per zone. So pretty different than 3 mins…
Now my question. As workaround can I use Portland watering durations per zone and than change the location back to the Netherlands and use Weather Intelligence Plus?
Second, when will the Netherlands be supported by Rachio for Recommended Watering Duration calculations? Can’t be that hard I thought.
rgds
bas
