Hi everyone,
About to switch out my Rainbird 16 zone, for Rachio 3.
Any tips / anything I need to be aware of when doing so?
Hi everyone,
Tips:
If during testing especially before moving wires, you might want to come back here to see what to do next. You might want to diagnose issues early so you know you are starting from a clean slate. If you do not do that, you might get frustrated with Rachio even though it is not Rachio’s doing. It does seem like sometimes even moving wires will cause issues such as a wire breaking that you do not notice.
Hopefully I did not miss anything and others will jump in here.
Thanks for the detailed help!! I’m going to try switching things early next week. I have 9 sprinkler zones and 2 drip. Everything is “working” ok on the Rainbird (we just started it up again for the year).
Great, let us know how it goes if you will please
I think Thomas Lerman’s response covered it well. I converted a 22 zone RainBird system that had 3 cables with repeating colors and I labeled everything obsessively. My wires were too short so I did a patch panel type thing which worked out great. After it was all labeled and organized the actual wire moving took only a few minutes.
Depends on your weather but most of our summer rain is from thunderstorms that the Rachio weather network doesn’t get right so in my case I’d absolutely hook up the rain sensor.
I’m labeling them all now.
Any idea why zone 1-3 and 11 would have much thinner, multi-colored wire?
Also, the sensor seems to be only a single wire with red/black ie not powered?
I swapped out my homebuilder-provided Rainbird ESP-ME3 controller for a Rachio 3 last year and it was straightforward. Thomas_Lerman provided a very good, detailed list of what to do. Seeing that many of your zones have red wires, labeling them before disconnecting is important!
For the sensor that is connected to your Rainbird, if it is a rain sensor, I suggest you check out this page before re-wiring: Rain Sensors FAQ
I have a rain sensor and eventually disabled it within the app, since activation notifications were a nuisance and the Rachio does such a good job of integrating local weather information (I am using the Flex Daily schedule and am connected to a local personal weather station).
I hope this helps, and best of luck!
I think it worked brilliantly last year. My grass remained green and healthy, and based on my casual observations, my irrigation system ran at least half as much as my neighbor’s (still on the Rainbird controllers).
I did make sure I put as much information as possible when defining the zones (under the “Advanced” section when editing the zone) to try and ensure the Rachio had a good basis for calculating the soil moisture content.
