@Mikegoldnj Weather review from the team.
Here is raw data, does look like we are using your weather flow station (which is good).
{"timestamp":1688440819,"scheduleId":"XXXXX","weatherStationId":"MJG 01","scheduleCriteria":{"scheduleType":"FIXED","startDate":"2023-06-10","endSunTime":"SUNRISE","rainDelayEnabled":true,"freezeDelayEnabled":true,"windDelayEnabled":false,"climateSkip":true,"seasonalShift":true,"smartCycle":true,"cycleSoak":false,"thriveModeEnabled":false,"soakTime":0,"cycleTime":0,"zoneDelayTime":0},"freezeSkipApplied":false,"climateSkipApplied":false,"precipSkipApplied":false,"noSkipApplied":true,"freezeThreshold":4.0,"precipThreshold":6.35,"temperature":22.0,"forecastedPrecip":3.348,"observedPrecip":0.0,"totalPrecip":3.348,"moistureLevelPredictedAtNextRunIfSkipped":-5.544154421257904,"runStartTime":"2023-07-04T00:11:55-04:00","runEndTime":"2023-07-04T05:32:00-04:00","runIntendedTime":"2023-07-04T05:32:00-04:00","sourceWeatherStations":"109549","weatherServiceFailure":false,"skipValidation":false}
The forecasted precip was 3.348 mm (0.13 inches). It also looks like you have rain skip set at .25 in which is actually a lot of rain. If you had it set at 0.125 this particular schedule would have skipped as over the threshold.
I can’t comment on Tempest’s forecasting engine (accuracy vs. our default weather service) since it probably performs better in certain areas of the country, as they all do.
The one guarantee is that any observations will be directly taken from your property which will definitely help our weather intelligence engine accuracy. Hope this helps.
